Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...This was the ONLY place that I could find information that I could use to resolve the problem. So thanks once again to member TomSark and the SQL forum!..."
Geography
FDS2008 (Mechanical)
25 Aug 09 19:51
Fellow experts,
I am working on a security gate which will have an extruded rail beam acting as the track rolling on bearings and also supporting the fencing.
We will need to weld the fence (2 x 2 aluminum tube) to the rail beam.  Is there any literature out there (free of course) that I can read up to verify the welding procedures to minimize deformation (i.e. temperatures, welding materials, etc.)  The tubes are .125" TK and the top of the rail beam is 0.25" TK.
Thanks.
metengr (Materials)
25 Aug 09 21:09
Yes, see below. You need to know that with welding on 6XXX series aluminum alloys these are heat treatable and the base material adjacent to the weld region will loose strength. In this case, it probably will not make a difference, however, you should be aware.
http://www.brazing.com/products/Weld_alum/4043_5356.asp
http://www.alcotec.com/
The Alcotec site is decent and if you go to the knowledge center under the education tab there is technical information related to welding of aluminum alloys.
26 Aug 09 11:07
Thanks a million metengr, the alcotec site is super informative and what I was gunning for.
Close Box
Join Eng-Tips® Today!
Join Us             Close
