Parts List template: possible to predefine row height?
NX6.0.3 MP2
Is it possible to predefine a fixed, specific height of cell rows in a Parts List template?  This way, when a drawing is created using the Master Model approach, the Parts List will populate with a row height that is exactly what I want it to be a-priori.
I can't seem to figure out how to do anything but define a fixed specific height for the header row.
Thanks.
RE: Parts List template: possible to predefine row height?
if you set the row height in the template, then turn off word wrap it should stay the same height.  If that is what you are asking.
Hmm; I set the row height for the HEADER row, but I can't see a way to set a row height for the rows which get populated by the parts' attributes.  For example; I tried setting the row height to be 20, and when a drawing is created, the part attribute rows have a height of 7.
What I'd like to do is specify the value that is currently defaulting to 7, to some other number.
Does that explanation make sense?  Thanks.
When you create your Parts List Template you will need to have at least one Component in the Part file where your setting this up so that you will have at least one row to manipulate.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
