Weld build up of buttwelded valves
Is it possible to apply weld build up to valves to reach a higher schedule? For example, you have a buttweld valve with a lower schedule but you need a buttweld valve with a higher schedule, can weld build up be applied to reach the requirement?
RE: Weld build up of buttwelded valves
