Drafting view colors NX6
I need the colors in my views to relect model colors. Prefrences are so transformed from NX4 I'm lost to what's probablt obvious.
Thanks in advance for any help you can offer!
RE: Drafting view colors NX6
This took me a while to find as well.  When you edit the style of a view under the visual lines tab click on the colored rectangle.  One of the icons will say deselect all colors.  Then under the general tab you can pick the wireframe color source as from body or from face.
Steve
Thank you... I pecked around that "deselect" button earlier but didn't gave any luck. I'll try it again. Temp work around was using an NX4 template with all the settings.
Dave
You'll probably have to do this every time you create a new part without a template.  You should probably change your Customer Defaults (File -> Utilites -> Customer Defaults) to reflect the settings you want without templates, which should save you a bit of time in the long run.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
Some people are like slinkies....they don't really have a purpose, but they still bring a smile to your face when you push them down the stairs.
