Looking for some advice with pin problem
Hi, it's been quite a few years since I've done anything like this, so I'm a little lost at the moment.
I'm trying to do 2 things... First, I'm trying to clearly define my problem with a loading diagram. Second, I'm trying to decide exactly what kind of stresses I'm dealing with.
I have a series of 0.020" pins, which are ~0.350" long being assembled into a pin jack which requires ~60 grams of force to engage. Assuming that one or all of the pins are slightly bent, or being engaged slightly off center (and therefore, loaded from one side of the pin), how would I determine exactly how much bending or deflection is occurring in the pin (if any) while that 60 grams of force is being applied?
Any help is appreciated.
Mod
Mod
RE: Looking for some advice with pin problem
For calculating stresses, go to a strength of materials book and use one of the column equations, plugging in the known geometry, modulus and force, being consistent with the units.
I was wondering if both ends of the pin would be fixed? At one end, the pin is contained within a metal/glass housing, which is static and at the other end it is being engaged into the connector... It shouldn't move until the engagement force is achieved.
Do you disagree?
Axial force is 60/454 lbs. Moment would be determined by your off-center distance. Hopefully you will be able to find the equations for the critical load and for the deflection curve so you won't have to set up and solve the ODEs. Also note everything is a function of pin insertion distance (column length) with maximum occurring at L = 0.350.
