Suggested distractor mechanism, any help?
Dear all mechanical engineers,
I have a problem and I would like to know if you can help me to get a solution:
Our system consists of a fixed plate, a mechanism, and a mobile plate. When the force applied to the mobile plate is equal to Fa =150 N, the mobile plate is stable (Case 1). As this force decreases, the mobile plate must move upward till the applied force is once again equal to Fa (Case 2). The mechanism should be locked after this movement. What type of mechanism could we use to achieve this giving that the initial distance between the plates is 5 mm and the maximum allowed distance is 10 mm?
Illustration: htt p://files. engineerin g.com/getf ile.aspx?f older=ebb4 8677-a214- 49b6-ba8e- 53c60e5e53 9b&fil e=Idea.bmp
Thank you in advance;
Chaabain
Illustration: htt
Chaabain
RE: Suggested distractor mechanism, any help?
A linear motor like SMAC or Linmot can be positioned and detect load on axis. Again not sure if it can hold position and react change in load. Only thing I think would work would be some sort of servo axis with a load sensor.
Getting it to fit into 5 mm and expand to 10 mm would be some engineering feat. Some sort in miniature scissors lift?
Sorry if this is no help
James Spisich
Design Engineer, CSWP
I think that the miniature scissor lift is a good solution, but we need to actuate the lift and consequently is it possible to find a miniature actuator that can push the upper mobile plate with the suitable force?
On the other hand, air bellows may also be used, but I dont'k know about these bellows if they need a source of air because I need my system to be completely independent. In other words, I need the source of kinetic power (electrical, pneumatic, ...) to be also embedded within the system.
I would be so grateful for any more information may help.
Thank you in advance,
Chaabain
The bellows might be low enough profile to fit into 5 mm space. Something like a bladder or inner tube. Look into metal bellows.
The dimensions of the lower and upper plate are:
Width: 32 mm
Length: 37 mm
Height: 2 mm
and as I said before, the initial distance between the two plates is 5 mm and the maximum allowed distance is 10 mm. I need the distractor to fit into this space. For the pneumatic and hydraulic way, I don't think that it works because I don't have enough space for the accumulator tank. A miniature electric actuator may work, but are there linear motors that can fit into this space or even the metal bellows, is it possible to fit overthere.
Thank you in advance for any further information.
Chaabain
After it's locked what happens if the applied force increases? It doesn't move? Ever?
I.e., how many times does this mechanism have to actually work? Example: If the answer is 'one', then the mechanism could be a spring in a balloon filled with wet concrete.
How many can you sell?
How much money have you got?
Mike Halloran
Pembroke Pines, FL, USA
To present, I can't tell you how many I can sell before you tell me how to do with this problem !!!
Thank you Mark for your idea,
Chaabain
I.e., so far you've described a spring.
Mike Halloran
It's exactly like a spring but must be locked by user whenever needed. That means I don't need this operation to last forever. I should lock and unlock the mechanism whenever I want and in this case, I don't care about the decrease or increase of force. It's like a spring with controlled lock, does it exist?
If you have any idea about that, Mike, I'll be so grateful.
Chaabain
Insert a shim between the platens? There's your lock.
User puts his fingers between the platens? Need guards and/or interlocks to protect the fingers.
Manual operation of electric switch controlling a solenoid that places a shim between the platens? Requires a power source.
Is a shim sufficient, or does the 'lock' need to prevent further outward motion in the event of an extra force applied in an outward direction?
You probably thought your first message carried a complete specification. Not so.
Mike Halloran
I think what you are saying is that you need the mechanism to equalize reflexively by expanding, is that correct? Like a locking spring, like mike said?
This thing is small, is there any more space to be had? what about what's under the fixed plate?
I'm thinking of using a custom stepping motor setup, with holding/breaking voltage acting as the lock
stepping motors are big though...i mean, they arent 37 mm across.
The electric switch controlling a solenoid, it's a good idea. But can it fit into the space that I talked about. For the power source, the mechanism may be powered by an exterior induction coil without the need to put a source of power in. Th lock must prevent the movements in all DOF if it's possible.
DragonTSD, for the relation, Fb = Fa, that means: when the force exreted on the upper plate decreases, the upper plate must move until the force Fb becomes again equal to Fb.
Yes, it's like Mike said. The problem is that I've to find a stepping motor that can fit into this space, and I've alread made a research about that, but I couldn't find this motor. The motor I need has a height of 5 mm and can expand to 10 mm and like that it's impossible, especially with the torque required to push the upper plate. Under the fixed plate, there is no space to be used.
Finally, I would like to thank you for your help and I'll be so grateful for any further help.
Yes Mike, you are right, the first message didn't carry a complete specification because I couldn't expect that I'll have such a help. If you are interested, I can describe the whole idea again with the application I need.
Many thanks,
Chaabain
Except for the 'lock', the specification for which seems to keep changing.
You can get a solenoid in the specified envelope. Less likely a motor.
Transmission of power by induction requires two coils. Is there space outside of the problem gap for a coil?
Yes, please try to write a complete and coherent specification. Try to design something to meet it yourself; that's one way to improve a spec, by forcing you to ask the questions we would ask of you.
Mike Halloran
Kind of like a cam.
Fe
Fe
Dear Mike, I'll try to write a complete specification as you said and back again.
Dear FeX32, for this motor with elliptical shape, can it fit into the small space that I have and is it able to push and expand with the required force?
And for the scissor mechanism,as I said before, it's very good idea but I didn't understand how to actuate it and lock it when needed with taking into account the small space that we have, do you have a full description of that?
Thanks again for all of you,
Chaabain
I've an idea about "Actuation in induction" but I don't know if it will works or not. Do you have any idea about that?
Thanx
I would also contact Servometer with your problem. They can do many things with their bellows and are capable of making very small bellows.
http://www.servometer.com/
But as I said before, the actuator of this mechanism must be inside the aforementioned available space. In case of metal bellows, I need either heat or pressure to actuate the bellow and that's impossible in my application. Can there bellows be actuated to expand and retract by providing them in an electrical power (from battery for example)?
Chaabain
We also used a thermal heating fluid filled bellows that operated around 600F in a condensate trap.
Checkout this page on the Servometer website.
ht
Do you have any reference that can explain exactly how do these bellows work?
Chaabain
The thermostat uses a wax mixture with high thermal expansion to move the piston.
Here are some wax driven thermostatic elements from China. There is also a lot of good information on the design of temperature sensative switches and things.
http://www.wax-thermostatic-element.com/index4.htm
Does the mechanism have to be housed between the 2 plates? Why can it not be placed above the upper plate? Fully self-contained?
Unclesyd, I will contact servometer to get this application manual and I'll see what I can do with.
Htlyst, im my application, the mechanism must be between the two plates. Furthermore, the change of electrostrictive and magneostrictive materials as a response of the applied force or magnetic field is too small - of the order 10e-6. As I told before, the change must be between 5 and 10 mm.
Thank you a lot for any further suggestions.
Chaabain
No?
Sorry but I didn't understand exactly how we can do that under the conditions that I've talked about.
Using the metal bellows that you have suggested. I made an illustration of my application to get an answer to the following question:
Taking into account the initial force applied to the upper plate (given that F1 = 150 N), how could we actuate the bellow when F2<F1 untill F2 = 150 N once again? How could I lock the actuator when needed without taking into consideration the change of force exerted on the upper plate?
Chaabain
You keep saying "How could I lock.." while defining an envelope that apparently allows no penetrations or extensions for remote control or energy storage or observation. You have also not made it clear what "lock" means to you in this context.
You are talking in circles. While it's possible to make a good living doing that, it's an unusual behavior among engineers. When are you hoping to graduate?
Mike Halloran
Sure you are right, it's improperly dimensioned, but it was just to illustrate the idea. Let's say that expanded height is 7 mm (I didn't use a CAD software to illustrate that). For the lock, you can penetrate the envelope by a good idea that I couldn't imagine."Lock" means that the upper plate will never move to balance the force else if the user allows. I'm still a young undergraduated engineer and I have no experience concerning the question that I've asked.
Anyway, thank you MikeHalloran for your reply. I look forward to get your suggestions.
Function one is the phsyical control of the gap and the ability to lock it anywhere.
Function two is to measure the force and use that to control the mechanism.
Roller cams along the edges or paired wedges with strain gauge sensors.
Actuators for the cams (rotational) or wedges (linear).
Actuators controlled by micro processor based on feedback from the force sensor and with a programmable algorithm that controls cam/wedge movement anyway you like. Speed of response, smoothing, define and ignore transients, hysteresis, direct acting and reverse acting, fail safe overpressure response, and so on..... anything you like.
JMW
www.ViscoAnalyser.com
Thank you in advance for any further suggestion.
Then use hydraulic oil to fill the cavity. If you close the inlet/outlet valve, that will provide an effective lock.
Alan Simpson suggested looking into stainless steel bellows.
Try here:
http:/
or
http://www.htproducts.co.uk/vac/vacbellows.html
for example.
A minature pump or a nitrogen pressurised bladder have already been suggested.
JMW
Mike Halloran
Mike Halloran
JMW
JMW
In your case a helical spring fitted around the rod and between the plates would provide the saparating force.
The "unlock-reposition-lock"system would be controlled by a pressure sensor on the top plate actuating,by appropriate logic,a lock plate solenoid.
If you focus on the design of the lock plate you could reduce the actuating force to a level where quite a small battery could operate the system.
