Manufacturing : Feed Rates question...
I can change feed rates like engage, rapid, approach etc.
But How to change feed rate in cutting area?
For example I need feed rate change at some points of cutting area :
I tried to do it with "Tool Path"->"Edit" but there is no diapason selection there I can change feed rate only one selected arc.
RE: Manufacturing : Feed Rates question...
John Joyce
Tata Technologies
1675 Larimer St.
Denver, CO
www.myigetit.com
NX3,4,5,6 Solid Works, Pro/e, Solid Edge
Not sure what you mean by "diapason selection".
Thanks for the answer. Take a look at the attached picture to find out what I mean by "diapason selection".
