UG-41 Strength of Reinforcement
UG-41(b) says I can use the minimum of W, W11, W22, and W33 in evaluating nozzle weld strengths. In the case of Fig. UG-41.1(b), if if A1>A then W<0. Does this mean ANY nozzle attachment weld strength is acceptable, as long as the weld meets UW-16 requirements?
RE: UG-41 Strength of Reinforcement
Yes, indeed.
That code rule is intended at verifying that all the material added for reinforcement outside vessel wall is effectively connected to vessel wall, so that it will perform its function.
But, when A1>A, there is no need of any more reinforcement outside vessel wall, so no need to check that such non existent reinforcement is correctly attached.
prex
http://www.xcalcs.com : Online engineering calculations
http://www.megamag.it : Magnetic brakes and launchers for fun rides
http://www.levitans.com : Air bearing pads
