Ontario Building Code 2006 - Vehicle Live Loads
I"m told that the OBC 2006 Vehicle Live Loads are as follows:
Area load is 12kPa
Wheel point load is 54kN.
Working down in the States I don't have access to this code. Could some please verify this and provide the length and width of the wheel.
Thank you in advance for your assistance.
Respectfully,
PESteward
Area load is 12kPa
Respectfully,
PESteward
RE: Ontario Building Code 2006 - Vehicle Live Loads
Vehicle live loads as per OBC are as follows:
Uniform Loads
Garages for passenger cars = 2.4 kPa
Unloaded buses and light trucks = 6.0 kPa
Loaded buses and trucks and all other trucking spaces = 12.0 kPa
Concentrated Loads (over 0.75m x 0.75m area)
11.0 kN for passenger cars
18.0 kN for vehicles not exceeding 3600 kg gross weight
36.0 kN for vehicles 3600kg to 9000kg
54.0 kN for vehicles over 9000kg
54.0 kN for driveways and sidewalks over areaways and basements.
There is some discussion that the newer types of fire vehicles may exceed the above noted loads.
I do not what you are desiging but like Aashtto we have CBHDC . So make sure which loads r u designing for. Than we ahve candian steel and cocnrete codes.
BA
also, using the OBC, live loads and dead loads must be factored.
