Alternate to NAVMAT P-9492( ESS Tests- Vibration and Thermal)
4
1)Navmat P-9492 (Navy Manufacturing Screening Program, May 1979) provides guidance for conducting  thermal and vibration tests to eliminate most latent workmanship defects in  avionics electronic equipment. I understand  the doucment has been canceled.
2) I would like to know  if there is  any another (similar) document that is suitable, available and is currently used in military/commercial applications to conduct ESS tests (thermal/vibration) to eliminate latent workmanship defects.
Thank you.
RE: Alternate to NAVMAT P-9492( ESS Tests- Vibration and Thermal)
One school of thought is to "seed" latent defects into components.  Then perform developments tests to determine the environmental levels need to precipitate the defects.
Sincerely, Tom Irvine
http://www.vibrationdata.com
rama
Take a look at MIL 810F
abd Mechanical Environment
Test specification development Method By Christian LALANNE
MIL-HDBK-2164A ESS Process fo Electronic Engineering (for guidance only). - available at
http://astimage.daps.dla.mil
Tri-Service Technical Brief 002-93-08 Environmental Screening.
