How to dimension a pin like the end of a G-clamp handle
Hi All,
I am trying to dimension a 2mm pin that has a clearance fit perpendicular to the axis a 6mm rod.  The idea is to retain the pin inside the rod but flattening the ends of the 2mm pin like we see on the handles of G-clamps.
How would i represent the flatten edges and dimensions it on the drawings?  does any one have experience in this?
Thanks in advance!
RE: How to dimension a pin like the end of a G-clamp handle
You could sketch the defining profiles, path and guide curves, and create a sweep.
You might also be able to use the Deform tool.
I like the idea of using the deformed tool as the idea is to crimp the two edges of the tommy bar.  I will come back if i dont manage to deform it
Thanks for the help!
I'm not having any luck on the deform tool and i can't find any help what so ever with how to use the function..
does any one know how to use the deform tool?
