Refrigerant piping length
I am new to HVAC design and need help on the following issue:
I have specified a number of house hold Split Units for an office complex. The split units are relatively small, most of them providing 3.2 kW of cooling. I need to run the piping for 25 - 30m, as the only available space for the condensers are at that distance. On the data sheet, it states that the piping length should not exceed 20m.
My questions:
1) How much would the efficiency typically drop if I would exceed the max piping length by 5m
2) How much would the capacity of the unit drop if I would exceed the max piping length by 5m
3) I have over-sized ALL the units by about 20-30%. Would this "contingency" be enough to deal with the extra 5 - 10m of piping?
My questions:
RE: Refrigerant piping length
Thanks!!!!
2. Is it the equivalent length ? Have you accounted for the fittings ?
3. Apart from specifying the maximum length, the manufacturers also indicate the maximum vertical lift allowed.
4. Best way forward would be to get a back-up confirmation from the manufacturers on the maximum allowable length (vertical and total) along with the drop in capacities for the length specified.
5. Split units for office ? How big is it ? Where does fresh (outside) air come from ?
HVAC68
1) The 25 - 30m is horizontal
2) Yes
3) There is no nett vertical lift
4) Thanks, I would consult the supplier on the capacity drop
5) Fresh air is provided by means of a fresh air supply duct. The offices are small, in the range of 20m^2, therefore the units are sized at 3.2 kW and 5 kW.
Some background: This is a small offices complex within the concourse area of a large station. The client has requested changes to a HVAC system that was designed previously. I was not part of the previous design team, so I am changing the design to client specification. They requested the use of split units wherever possible.
Trust the fresh air supply is treated and not untreated. Untreated fresh air can cause condensation.
HVAC68
