COSMOSworks and wood
I'm running a model that contains both SS and mahogany wood. I can run cosmos on the SS support and it runs fine. But after finishing the study on the wood I get an error message when I try to run the study that says "please define Elastic modulus in material properties". I've looked at all the help sections and can't find any good info on this. So...How do I define the elastic modulus?
RE: COSMOSworks and wood
When selecting your material there is a table of material properties available.  Wood is orthotropic so you will have to define the elastic modulus in three planes.  Properties for wood are not included by default in the cosmos material library.
I have not worked with any wood material before so I'm not sure of a good reference for these properties
It scares me that someone is using an FEA package and doesn't know what Elastic Modulus is.  This is a case of the simplicity of the package being to detriment of high end users.
-Dustin
Professional Engineer
Certified SolidWorks Professional
Certified COSMOSWorks Designer Specialist
Certified SolidWorks Advanced Sheet Metal Specialist
here is a better one... that discusses the orthotropic topic that mbc2009 brought up.
http://books.google.com/books?id=mUGSaiTsBAIC&;pg=PT67&lpg=PT67&dq=mahogany+modulus+of+elasticity&source=bl&ots=yzJddWMVQP&sig=DaoX7_FqaqAaJwLG37EpdJ4498E&hl=en&ei=GGyPSqXmB5CusgPFkZEP&;sa=X&oi=book_result&ct=result&resnum=9#v=onepage&q=&f=false
-Dustin
Shaggy, he didn't ask what the elastic modulus was.  He was asking how to define it in Cosmos.
OP, you will have to go back into the SW tab and edit the material definition.  I'm not sure that you can edit them while in Cosmos
Material properties are accessible in CosmosWorks. Look at the material definition for each part by RMB on the part.
On another note, there is a CosmosWorks Forum where the Cosmos users hang out. This forum is for the CAD side of SolidWorks.
TOP
CSWP, BSSE
www.engtran.com  www.niswug.org
"Node news is good news."
