Plate Girder Shear - Tension Field Action
AISC 13th Edition, Section G.3.1 gives limits on the when you can use tension field action for shear. The first one says not allowed in "end panels in all members with transverse stiffeners."
I can't find a definition for "end panels." My common sense tells me that it's the first panel of web from the first to the second set of transverse stiffeners. But I don't always like relying on common sense. I'd like for there to be a definition in the code.
RE: Plate Girder Shear - Tension Field Action
