FE Worked Examples
FE Worked Examples
I have access to a FE program called Lusas. I am used to it and like it but its manuals have rather limited worked examples.
I wish to apply Lusas to some Civil/Structural problems (mainly non-linear problems like buckling, non-linear materials and support conditions, dynamic problems etc.)
I am looking for worked examples in other programs that I can easily access and compare with Lusas results.
I will appreciate if you can suggest any books or sites where I can access such worked examples.
RE: FE Worked Examples
You should also be able to find several by searching university sites.
http://ww
http://www.comsol.com/showroom/field/189?page=2
Fe
Check ADINA of Prof. Klaus Hürgen Bathe (MIT MechE), an excellent nonlinear code plenty of very good examples:
http://www.adina.com/
Best regards,
Blas.
http://ww
You have an Examples manual with many problems solved step-by-step, very good to learn the use of FEA.
Best regards,
Blas.
Your leads seem all very helpful. At a first glance, it looks Ansys has the best tutorials, that can be accessed free on-line.
