Applied Pressure vs. Time Plot
Hi All,
I need help on extracting a plot. I did a pipe collapse analysis by applying external pressure. Now I want to obtain a plot of "applied pressure versus time".
Can anyone please tell me how to do this?
RE: Applied Pressure vs. Time Plot
Try using results tab and press XYdata. After that select 'ODB field output'. A window will pop up and select 'Unique model' from the output variable scroll down menu. This will show your desired field outputs. Select Pressure and then press the tab 'Element/nodes'. and pick your node from the viewport and then plot. You should get your pressure against the time plot.
Hope this helps
