What is the "Force attack angle" in Loading table for leg's report
Now I concerning about report of Leg support analysis from Compress, but  I have don't understand about "Force attack angle" in the loading table. What is this value and how to clarify this.
RE: What is the "Force attack angle" in Loading table for leg's report
Due to the lack of axisymmetric geometry of the leg and lug supports the loading applied to each leg (or lug) will vary depending upon the direction that the wind (or seismic) force is applied in. COMPRESS takes this into account when determining the maximum loads applied to the supports.
   "Although this forum is monitored by Codeware it is not intended as a venue for technical support and should not be used as the primary means of technical support."
  Tom Barsh
  Codeware Technical Support
  www.codeware.com
