Radiation Fundamentals
Hello Everyone,
Recently, I was trying to explain the fundamentals of thermal radiation to a non-engineer and I discovered that I myself have a poor understanding of it. I understand that "thermal radiation is continuously emitted by all matter whose temperature is above absolute temperature." However, I do not understand who or what is causing these electromagnetic waves to be emitted. According to my textbook [HEAT TRANSFER: A Practical Approach, 2nd ed.], "accelerated charges or changing electric currents give rises to electric and magnetic fields. These rapidly moving fields are called electromagnetic waves or electromagnetic radiation, and they represent the energy emitted by matter as a result of the changes in the electronic configurations of atoms or molecules." In layman's terms, what does this really mean? When atoms heat up, they bounce around faster and faster and produce more and more electromagnetic waves? Why does bouncing around create electromagnetic waves anyway?
I suppose that I was too busy trying to solve partial differential equations to think of these kinds of questions in college. There was no time to think or ponder. This seems to be the trend as I try to go back and relearn subjects. I gave all the right answers on the tests, but I think I missed some of the more important fundamentals. Those were not on the tests.
Thank you all in advance!
RE: Radiation Fundamentals
You're not alone. This is that aspect of physics where wave form theory concides with particle theory. If we had such a good handle on this to explain it properly in layman's terms we'd be on a forum for quantum physicists not engineers.
Try thinking of radiant heat just as energy getting thrown out of the molecule as the atoms bounce around more and more rapidly. That energy hits something and that something warms up as a result. Just as it would if you hit it continuously with a hammer instead.
The energy loss at the source could be analogous to the noise (energy) you would hear if the atoms were all brass balls.
Hey! You said layman's terms.
Previous answers are correct. Microscopically, thermal radiation is associated with thermal motion of atoms and molecules, so it is not surprising that it increases with temperature.
In 1900 the German physicist Max Planck described the thermal radiation arising from the vibration of molecules, and established that energy emitted by a vibrating molecule is quantized, meaning it can have only certain discrete values. His revolutionary work won Planck the 1918 Nobel Prize.
A third part of the radiation problem is the (usually) two ABSOLUTE temperatures involved. NOT the two RELATIVE temperatures involved between the two materials.
A fourth part is is the surface textures and colors and physical surface area involved between the (two) heat exchanging surfaces. NOT the materials of the surface themselves, nor their amount of "touching" surfaces as is the case for "normal" heat transfer.
So, to a non-radiation transfer person, even to most engineers!, explain it as follows: EVERY surface at ANY temperature emits infrared radiation - what we "feel" WITHOUT touching a surface as the "heat" coming from that surface (the stove top burner, the fire, the refrigerator shelf, the ice cube tray) of that material to our hand.
Our hand, in turn, is ALSO radiating energy from our hand to that surface (the stove, the fire, the oven door, the refrigerator shelf, the ice cube tray). How much radiation is emitted is proportinal to the type of surface (reflective and smooth and shiny, rough and black and textured like a sandpaper-covered basketball) and the absolute temperature of the surface.
Absolute temperature is calculated from true interstellaar space ZERO.ZERO So, a black basketball at room temperature is at 25 degrees Celcius, and is at 273 + 25 degrees = 298 degrees Kelvin. It will radiate according to the fourth power of the temperature in degrees K. So a stove at 212 Farenheit, 100 degrees C, is at 373 degrees Kelvin. Far hotter than 298 degrees K, and even more when 298^4 and 373^4 are compared.
Like light waves, emitted when the stove starts to glow orange then red hot if nothing is on the burner - snd like light waves emitted from a light bulb when it is heated by electricity - every object when heated emits more infrared radiation and more heat by radiation as it gets hotter. But heat transfer by touching (conduction) and convection (movement of cold liquids) is more efficient than by radiation - put a cold pot with cold water in it on the oven burner, and the pot cools the burner much, much more quickly. With no pot on the burner, the burner just kept getting hotter until the rate of radiation can equal the rate of radiation. (Which may not happen until the burner melts!)
But, the air between you and the stove is an insulator, so only radiation heat can be transferred if there is no pot.
In a vacuum or thremos bottle with hot coffee inside, only the radiation from inside can transfer heat energy out: So, the vaccum helps insulate the suspended (not touching!) silvery bottle. Little radiation because of the silver surfaces? Little heat transfer = Your coffee stays hot longer. Put a cold drink in the same thermos, the inside gets colder than the outside. the radiation of energy is by the same infrared energy photons, but this time many more photons go from outside surface to the inside surface, and the previously cold drink gets slightly hotter.
the IR transfer is by photons (little wavelets of energy packets - as technically described above in terms of "real" physics) going from one surface to another. In space, the "background" of "nothing" is also available to radiate energy into from a surface or mass like the earth itself or a satellite or manned vehicle. The gold foil wrapped around the lunar lander was to reflect infrared energy to help maintain the lander inside from getting too hot in the direct sunlight, and too cold in the shadows of the moon when the sun was hidden.
Star for you! That's a really good explanation.
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
So, we know that blackbodies generate photons in the spectral distribution described by the blackbody equation. We know that energy can be accumulated in both the atomic bonds and electron energy levels. We know that excited bonds or electrons eventually "decay" to a lower energy level by giving up photons, or gain energy by absorbing photons. And, in most cases, there is a finite lifetime for the excited state, before it decays to a lower energy.
Thus, for a blackbody's surface atoms, which are at the boundary between something hot and something cold, energy must flow through these atoms from the hotter interior to the colder exterior ambient. Some of the energy is conducted away through momentary contact with air molecules, which is the basis for convection cooling. Another portion is, because of the finite lifetime of the excited states, releasing photons everywhich way. The ones that head outward contain more energy than the ones emitted toward the blackbody from the cooler ambient, so there is a net deficit, and the surface is cooled.
Since the interior of the blackody is hotter, there is a net surplus coming from the interior that attempts to raise the temperature of the surface. If the energy outflow at the surface were zero, as in the case of a perfect blackbody cavity, the surface would be able to sustain the temperature of the interior. If the ambient is cooler, then there would be a net loss of energy, which accounts for the temperature gradient from the interior to the exterior surface.
TTFN
(But knock me firmly upside the hardhat next time I write without a more thorough spell check ...)
Speaking of the fundamentals of thermal radiation I took the liberty of reproducing the following excerpts taken from the internet:
Outstanding! Thank you all for your excellent feedback. I would especially like to thank those of you who took the time to leave such extremely detailed explanations (stars all around). I greatly appreciate you taking the time to respond to my post.
If anyone wishes to continue this discussion I do have a follow-up question.
I noticed that thermal radiation (radiation emitted by bodies due to their temperature) defines a portion of the electromagnetic spectrum that includes the entire visible and infrared radiation as well as a portion of the ultraviolet radiation.
Does this mean that if a body was subjected to strictly visible light it would heat up? Or, is it just the infrared and/or ultraviolet portion that causes objects to heat up? Or, does all types of radiation cause objects to heat up?
Thanks again!
The absorption on radiation is dependent on the object's absorptivity, which may not necessarily be a constant for all wavelengths. Thus, one can imagine, and actually build, a material that transmits visible, and reflects infrared, or the inverse.
TTFN
Infrared and visible light are low energy radiation that usually only results in heating when absorbed. Ultraviolet and higher energy radiation referred to as ionizing radiation because the energy is enough to knock electrons out of atoms. This cause sunburns.
Thank you for both of your valuable replies!
