ABAQUS
ABAQUS
Could anyone kindly explain what is the link between CYGWIN and ABAQUS?
RE: ABAQUS
You might try red flagging this post and re-posting your question in a more specific forum on this site, probably the one below, or have a search through the old posts there.
Engineering Computer Programs > General Engineering Programs > ABAQUS: ABAQUS FEA Solver Forum
Good luck!
RE: ABAQUS
From what I found it looks like CYGWIN is an alternavite to going with Hummingbird Exceed to run ABAQUS on a Windows based machine.
The last time I set up ABAQUS this was required since ABAQUS was not 100% ported from UNIX base. Your link that you are asking about would be basically an interpreter for the OS and ABAQUS. I think the copy protection as also required to use this link as well but my memory is fuzzy on that one.
__________________
Rob
"We can't solve problems by using the same kind of thinking we used when we created them." ~Albert Einstein
RE: ABAQUS
I have run Abaqus just fine on Win (XP, XP-64 and 7-64) and Linux (Suse 9.?).  If this is a port from Unix than this is possibly not needed anymore.  I hope this helps.
Rob Stupplebeen
