Need help with a mechanism design
Need help in locating details of a trash can open/close mechanism, ie.. flipping a trash can lid open by stepping on a foot pedal. Actually I need to do the reverse motion, closing the lid(by rotation) by displacing a smaller linear movement. Hope someone can help.
RE: Need help with a mechanism design
"Happy the Hare at morning for she is ignorant to the Hunter's waking thoughts."
A--->|
OB
C O---->D<----(Lid)
Image a triangle (bellcrank) made of BCD, with C being a pivot. There is a verticle member going up from B that pivots... there is a horizontal member from D attached to the Lid with a pivot.
If you apply a force (A) down on the lever connected to B, the bellcrank will rotate about C, making point D rock CCW. This motion would open/close your Lid. There are a zillion combinations of this system that are used in even more applications in almost everything. Playing with the ratios between BCD will give you different mechanical advantages and movements.
I think this is what I am looking for. Thanks very much for your help.
