two way shear on elevated slab
I am trying to evaluate 2-way shear in a thin mildly reinforced elevated slab. The equations I have (see attachment) reference a soil pressure factor (R). I believe it would be correct to treat this equivalent to 0 in this case. The reference comes form Lindeburg's PE review book, as I cannot find the specific ACI reference to punching shear. Can anyone tell me whether it is correct to leave out the R factor when evaluating an elevated slab, or where ACI references punching?
Please forgive the naivete, I do not typically design slabs/footings...
RE: two way shear on elevated slab
I am intrigued. Why wouldn't you take the shear at the bo perimeter?
I agree that unbalanced moments need to be accounted for.
BA
Whether anyone bothers to do it is another matter.
BA
If you are calculating punching shear failure, there are several options:
-drop panels (PS make the extra slab depth = a true common wood size, the contractor will appreciate it)
-column capitals
-shear rails in the slab
