Testing Welds in solidworks
Hi All,
I have a rack system created on solidworks and I can not figure place a weld between two components in an assembly the run a FEA on the assembly. So far I can only run FEA on a single part. If anyone could help out with running an FEA on an assembly and how to put a weld in that would be greatly appreciated!
Thanks Folks!
Thanks Folks!
RE: Testing Welds in solidworks
If you cause the parts to touch you can bond them together.
TOP
CSWP, BSSE
www.engtran.com www.niswug.org
"Node news is good news."
Cheers for all the help!
You might also want to check and see if your industry has standards for dealing with this.
You are correct, different welds are treated differently. The AISC handbook has a discussion on this subject.
TOP
CSWP, BSSE
