2 updates required
2 updates required
I have a weldment model that is highly parametric, a few initial sketches drive every aspect through almost 40 equations and a dozen variables.
Everything is working great except when I change the sketches the model will rebuild and have errors, but then if I hit ctrl-q it rebuilds again and everything is fine.
I need to track down this behaviour and figure out how to prevent it, but I'm not even sure where to start.
RE: 2 updates required
Rob Rodriguez CSWP
www.axiscadsolutions.com
www.robrodriguez.com
http://www.robrodriguezblog.com
Eastern Region SWUGN Representative www.swugn.org www.nvtswug.com
SW 2007 SP 2.0
I'm good. How are things north of the border? Still working for yourself?
Rob Rodriguez CSWP
SW 2007 SP 2.0
Which version are you using?
I installed 3.0 and had these issues. Last night I updated to 4.1 and everything seems to be running much better.
Chris
SolidWorks 09, CATIA V5
ctopher's home
SolidWorks Legion
If your part updates correctly with 2 CTRL+B rebuilds then the problem may have to do with order of your expressions.
If it updates with a single CTRL+Q then you should be okay. If it takes 2 CTRL+Q s to update the model correctly take a look at order of equations.
If you are referencing a Variable in an equation make sure the value of that variable gets calculated higher in the equations list.
Michael
