DELET MULTIPLE LAYER CATEGORIES AT ONCE?
Hi All
Is there a way to delete multiple layer categories at once?
I imported a dwg file which brought in a bunch of unwanted category names with it.
NX5
James
NX5
James
RE: DELET MULTIPLE LAYER CATEGORIES AT ONCE?
However, that will NOT be a problem with the new enhanced Layer dialog implemented in NX 6.0 where it will behave more like a 'navigator' window. You will be able to select multiple objects using normal Shift-select for a range or Ctrl-select for adding or removing items from a list of selected objects, in this case, Category Names, and then performing an operation on all of them at once, such as 'Delete'.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
