Unusual stopping of the generator
Dear folks,
I am a newbie here, so please don't mind if i am not that descriptive of the subject.
Well, we have a 15 MVA synchronous (hydro) generator with 14 poles, rated speed of 428.6 rpm and moment of inertia of 12,000 kgm2. Recently, the machine tripped on some temperature fault and the machine came to a complete standstill within less than 3 minutes against a normal time of 35-40 minutes. We don't have any type of braking mechanism put in place. We were completely shocked by its unusual behaviour and inspected the runner, the NDE and DE bearings, air gap, IR of the stator windings, XLPE cable, etc. Everything was normal but we were skeptic to run it. However, we did run the machine and everything was just normal.
I just want to know whether anybody has ever experienced such incidence or have knowledge about what could be the reason.
RE: Unusual stopping of the generator
I have not seen vertical hydro machines without any brakes/jacks, which are applied to low speeds to protect the thrust bearings.
Horizontal machines usually have a braking jet for the same purpose.
What sort of temp alarm that tripped the machine in the first place ? Winding ? Bearings ? Cooling Water ?
As far as I can remember, a sync generator can be stopped very fast if the 3-phases of its stator are short circuited till it is stopped, but at a reduced field current.
Could you please think of such a situation - such as unexpected gen breaker re-closing during its shutting down period?
I am sure that one of our learned members will throw some light on this braking method.
There was no sign of stator winding terminals getting shorted. Moreover, the chances of the unit breaker re-closing is not possible as the syncheck relay will not allow that to happen and the events in the SCADA also doesnt show of any such reclosing.
1> For some reason such as a misaligned nozzle or a partially flooded scroll case, the water acted to brake the generator to a rapid stop.
2> For some reason the generator was running below rated speed with much less inertial energy and so came to a stop much quicker than normal.
3> Instrumentation error. The stop time was normal but for some reason was reported as much less than normal.
On a completely different tack, is it possible that your control gear shuts down the water flow very slowly for a normal stop but on a lube fault, closes the control valve much faster?
Bill
"Why not the best?"
Jimmy Carter
Karmicpower:
A hydro generator disconnected from the grid, excitation then reduced to zero and with the Pelton nozzles closed is idling until coming to rest. If, however, the excitation is reduced to zero, the stator winding then short-circuited and the excitation thereafter increased to a point that rated current or even 120% rated current is generated, the resulting short-circuit losses decelerate the unit to standstill. The stator current remains constant until the speed is almost zero. Reason: Because the generated voltage decreases with speed (frequency) and the resulting inductive resistance decreases with speed also, the current remains constant. This is a very effective way to brake the unit. You confirmed that this scenario can be ruled out.
If the generator is disconnected from the grid and the stator remains excited, the iron losses would brake the unit as well but not as effective as in the short-circuit case as the voltage and iron losses drop with decreasing speed. Still, with the excitation on the unit comes to rest earlier than unexcited. Was the excitation still on in your case?
Your generator has not only two pedestal bearings. There must be an additional bearing which is limiting the axial shaft movement. Check this one. Also, is there some extra friction inside the Pelton wheel housing? Check for displacement of built-in components.
You may have had another occasion in the meantime where the unit idled until standstill. With the same result as mentioned in your original post?
Wolf
WWW.HYDROPOWER-CONSULT.COM
The unusual stopping time can be as mentioned, an error in observation.
Is this a remote unattended unit or is the station manned?
The next time the unit was stopped did you get the same result?
Do you trust the SCADA system actually, or is there an operator present?
It is unusual to be working on a unit when it is running, usually not allowed. If a wire was lifted on a RTD of course it will trip as the system sees high temperature.
Is there a thermometer on the bearing. What is the usual reading?
It can be leakage at the nozzles gives a protracted stopping time assuming the deflector is not in deflected position in a normal stop.
Is this a modern unit controlled by a PLC or an old unit that was automated?
In any case 40 minutes normal stopping time is very bad for the bearings unless there is a HP jacking oil pump which has to run during stopping and starting sequence. How about this?
As said was the excitation on or not? Is this a brushless,static, or classic DC rotating exciter? In some very old machines the exciter is always connected to the field /a DC shaft exciter that is/ and the excitation builds up as the unit comes up to speed.
What part of the world are you in? It has to be in the mountains somewhere...
It can be of course a bearing problem, was there any change in operating temperature?
regards, rasevskii
rmw
rmw
Bill
"Why not the best?"
Jimmy Carter
1. The nozzle wasnt misaligned as we did inspect it and also can be infered from the post incidence operation.
2.The machine was running on its rated capacity and speed prior to tripping. The droop characteristics would not allow for such variation of speed.
3.It isnt an instrumentation error either, I was personally present near the machine witnessing the event. I was dumbstruck by its awry behaviour.
4.We have a brushless excitation system. It got de-excited instantenously with the tripping of the unit breaker.
5.There are only two hydro-static bearings; DE and NDE holding the whole turbine-generator mass.
6. It is a manned power plant with the modern tech equips. We have RTU-SCADA system for the control and monitoring part and a microprocessor based digital governor for the hydraulic part.Both the systems have been reliable as of date.
7.35 minutes of coastdown time is normal. We have lube oil circulating until the machine comes to a complete standstill. The pump was in operation prior to reaching the standstill.
8. We inspected the bearing shell on both the halves. The white metal( babetted) was just as fine with no signs of stress or shearing.
9. We test ran the machine on unloaded condition. No unusual noise, smell or vibration was observed. The machine also did not come to a sudden halt unlike before. This very incidence have been the first of its kind.
The only explanation left: There must have been a temporary backsurge of tailwater in the Pelton turbine housing, thus creating a strong braking torque.
Wolf
How far above TWL are the pelton wheels? It can be the design is not the best or that the TWL was high due to other units at high load.
Not a problem. All power plants have their oddities....
rasevskii
There is an overspeed after the generator is tripped. Question is whether is was a full-load or part-load rejection. Nevertheless, because of the overspeed situation the coasting period is extended compared with a normal no-load shut-down.
The Pelton runner should be installed well above tail water level. However, if at the time of load-rejection some other units were operational under full load, the tailwater level may have been high enough to disturb the unit in question. Also, the tailwater channel may have been partially blocked or the tailwater could not have escaped properly because the tailwater outlet led into a stream or river with above normal water level. Was such a temporary flood scenario present at that time?
Wolf
The turbine is housed inside a casing/hood and we have had problem with the turbine efficiency attributed to the rise in tail water level. To cope up this issue, an aeration duct was later on put in place which almost solved the problem.
My doubt here is, due to the sudden throwing off of the load, a turbulence might have been created inside the housing which blocked the aereation pipe and resulted into momentary creation of vacuum. But will the vacuum have that amount of braking force to nullify the high inertial momentum of the runner?
Please highlight.
A sketch or photograph of the tailwater section and the aeration duct would be helpful.
Vaccuum would even increase duration of coasting. However, if vaccuum is resulting in increasing the tailwater level, this would be an answer. I can't imagine, however, that vaccuum was created and kept for so long. There must have been an unusual and temporary situation on the tailwater side.
You are mentioning that you were near the unit at the time of this incident. Was there anything noticable? Unusual noise or vibration?
Wolf
It can in fact be dangerous resulting in a failure of the wheel or the housing. See what happened in Siberia...
What every good pelton turbine wants to see is a tailrace channel the cross section of a garage door straight out to the river. The water leaves and never bothers the turbine again.
Forget about the noise. Most engineers find the sound from a pelton to be absolutely beautiful...
Why not send us some photos of your plant.
regards, rasevskii
Karmicpower:
Don't forget the noise. I didn't mean the humming sound comming from a Pelton unit in proper operation. I meant noise originating from possible contact with tail water.
Wolf
The symptom of the problem was a 10 to 20% reduction in power output. Not what one would expect of the buckets were actually hitting high water. But the turbine builder had stated that this was due to the increased drag created by spray or mist above the water. Breaking the vacuum dropped the water level as well as the layer of mist above it.
