NX4 Assert Value (mass)
The default mass unit on my installation of NX4 is 'kg'. However, when I try to assert a value for mass only, the prompt line says 'Assert values (in G -Mm) or mark as unknown'.
Does anybody know why G i.e. grams seem to be the default or where it can be changed to kilograms instead.
Thanks in advance.
Fred
Thanks in advance.
Fred
RE: NX4 Assert Value (mass)
Go to Analysis Menu --> Units and change the default units to g-mm.
Now Go to "Analysis" Menu and Choose "Mass Properties",Select the Solid Body , turn on "Keep Measure" for "Associative" .
Change the Filter to Mass, Now you get the Units in G-mm, Exprerssion also creates for this.
Pls let me know incase you require any help.
Srinivas Kumar.T
Head - Technical
G4 Solutions
Hyderabd ,India
WWW.G4SOLUTIONS.NET
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
