Program for nozzles loadings calculation
Hello everybody!
I am a mechanical engineer from Italy, working for a leader company in the centrifugal pumps' manufacturing field.
I am looking for some simple program/application in order to calculate loads on the pump's nozzles, once that the piping's loadings have been given by the piping's designers/stress analyzers.
Of course, my intention would be to verify the values given by this program, comparing them with the values given in Table 4 "Nozzle Loadings" of API Standard 610.
Thank you in advance for your kind co-operation & kind regards!
Tewma
Tewma
RE: Program for nozzles loadings calculation
Is your work flow structured such that the piping guys tell *you* the raw loads and then leave it to you to analyze the effects on the pump? I am just curious, since I am so used to having the pump guys give us their allowables and then feeding that back into the piping design.
SNORGY.
