Flow limiting valve
Flow limiting valve
Does anyone know if there exists a valve that allows unrestricted flow up to a given flow rate but restricts any flows that would exceed that given flow rate? For example, I would like to allow free flow into my system at flow rates of 0-6gpm with little or no pressure drop, but in the event of a sudden pressure drop in my system I don't want to allow more than 6gpm to enter my system.
Does this valve exist?
Thanks!
Thanks!
RE: Flow limiting valve
http://www.plastomatic.com/fc.html
the drawback is the 15 PSI or so pressure drop.
Steve
