Need a method to measure output of water wheel
Have a patent, made a model (1:12) and need a method of testing the output. There is a water testing facility at a nearby university that we plan to use, but need some form of machine to measure the power generated at given speeds. I am sure differing load conditions could increase or decrease the operational efficiencies, but don't know where to begin.
RE: Need a method to measure output of water wheel
How about a torque sensor on the output shaft?  That plus the RPM gives you the power.
Timelord
Thank you for the lead. After googling torque sensor, and seeing 3 to 6 thousand dollars, I am now googling torque sensor rentals.
(I wonder how Da Vinci did all this)
The thing you are looking for is a brake dynanometer. At its simplest it is a leather strap and a weight pan.
This book will give you some hints
Stronger Than a Hundred Men: A History of the Vertical Water Wheel By Terry S. Reynolds
However, these days we'd just plug it into an electric motor.
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
Since it's just 1/12 scale, hook it up to an alternator and measure the output.  If you want to do it really cheaply, dump the power into a load resistor, and measure the voltage with a voltmeter. Then use P=V^2/R to find the power.
If it is not invasive, what is the actual measurements of the 1:12 prototype?
Diameter?
Axis?
Foil Depth?
At 74th year working on IR-One2 - - UHK PhD - - -
I am about a month from releasing the overall design to the public, and would like to keep it offline for a little longer. I will post then, but for now we are going to just try and scale up the numbers that we get from the model that we built.
Thanks and I will make it a point to come back and post some numbers that can compare actuals to model, formulas to reality.
The use of a brake dynamometer as posted by GregLocock is the way to go. Lookup Prony Brake for information. For RPM measurement a simple mechanical speed indicator will do the job.
