is process modelling software available
Has anyone seen software for modelling the laser cutting process? With a cursory search of the web, I see that research papers have been written over a number of years. Have any of these projects become something useable?
Jay
Jay
RE: is process modelling software available
Almost all the work on improving the process seems to be carried out through a process of trial and tweek usually by specialists at the machine tools supplier although an experienced setter operator often comes up with a few tweeks themselves.
Dode
did you buy a system, or what?
Jay
Jay Maechtlen
We bought a DC system and so far have been delighted with the machine. Although I can't prove that it is directly related to the resonator technology the machine seems to produce a very stable cut at the top limits of the resonator. The downside so far is the low power control doesn't seem as good as the RF machines I have previous experience with. This has only really been evident in switching between cutting and etching, initially we seem to get some excesive depth in the etch.
Dode
if you are switching gases, make sure the head is purged- else you will start the etching with wrong gas (Oxy instead of N2?)
Jay Maechtlen
