U.S. Manufacturers of Re-built Transformers - 115 kV
I'm looking for recommendations for potential U.S. suppliers of re-manufactured or re-conditioned transformers.
Voltage class is 115 kV. Size is 15 to 30 MVA. Load-tap-changer is required.
Does anyone have any advice or experience, positive or negative regarding specific shops? The reason for considering re-built unit is delivery time, primarily.
Thanks.
Thanks.
RE: U.S. Manufacturers of Re-built Transformers - 115 kV
http://www.tdworld.com/bg.asp?codeID=114851&parentID=113468&siteID=30&magazineID=108
http://www.tdworld.com/bg.asp?codeID=114822&parentID=113468&siteID=30&magazineID=108
http://www.tdworld.com/bg.asp?codeID=114833&parentID=113468&siteID=30&magazineID=108
http://www.surplusrecord.com {links all seem session dependent}
TRANSFORMERS, THREE PHASE, 60 CYCLE 5000 KVA and Greater
115000 volt
http://www.ohiotransformer.com/frameset.pcgi?fm_dir=8&fm_content=remanufacture
