control valve lifting
3
good day guys, do you know the methods and tools how to lift bigger control valve on site?
RE: control valve lifting
1, A "Chain Fall"
2, A "Block & Tackle"
3, A Fork Lift
4, Two very big and very strong members of the Maintenance squad
Mobile cranes work as well.
Lift the body.  Some actuators are suitable for lifting the assembly.  The accessories are easily crushed by slings.
thanks guys for your valuable reply.
In all seriousness, consult the vendor about the correct lifting method (which may depend on the size of the valve.)  I've seen valves with lifting lugs to which you attach a chain.  Others do require slings.
I'd recommend lifting the valve and the actuator separtately if at all possible.
Patricia Lougheed
"Somebody on this Internet forum said it was ok" is not a sufficient explanation when responding to a lawsuit.
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
