Thread type in a Threadolet
Here's a total newbie question for you.
For Bonney Forge Threadolets they state the outlet size as a size in inches. But there is no clue as to what thread type it is. I can only conclude that its somehow assumed that the reader already knows. My problem, I don't know and there are a lot of threads to choose from, NPSC, NPSF, NPSI, NPSM, ANPT, NPT, NPTF, PTF etc. etc.
So, what is it that I am supposed to know in this case?
RE: Thread type in a Threadolet
page 17 of document (catologe page 15)
bottom of page
"Threaded ends are in accordance with ANSI/ASME B1.20.1
Design per MSS-SP-97"
That then limits my possible candidates to NPSC, NPSM and NPT. While I think we can rule out NPSM as it is for mechanical use I still don't know if it is a straight or taper thread.
PS I haven't got access to B1.20.1 or MSS SP-97.
Have you called your threadolet supplier to ask how you specify the thread type you need? Do you need the NPT type?
Thanks for your replies.
Virtually every US project is NPT
Do you have a pipe specification for the rest of the piping systems ?
I am setting up new internal component standards for ASME pipe fittings and adding our own article numbers and design directions. To simplify for the designers I would like to add this type of information from the outset rather than having the designers figuring this out for them selves each time.
Then You need threadolets with BSP thread.
Greetings
Thanks to all for taking time to help.
