Connections with Torsion
Hey all,
Are there any good references out there for designing connections for beams with torsion?  For example, a curved HSS member uniformly loaded along its length.  Any help would be appreciated.
RE: Connections with Torsion
Did you try the AISC Torsion Design Guide? I think it is Design Guide 7.
Is it a bolted or welded connection? Have you tried the bolt and weld tables in the steel manual?
