Delete references
Delete references
Delete references
It's been a few years that I have done this.
SolidWorks 2009 SP3.0.
I did a pack and go for an assembly. I opened the new assy, some parts are still referencing an old assy. Both assy's are same version and SP.
I can not find within SW or SW Explorer how to delete the reference.
I thought it was easily done in 2006.
I tried selecting 'references' when opening the part.
There is no option anywhere.
Chris
SolidWorks 09, CATIA V5
ctopher's home
SolidWorks Legion
RE: Delete references
The only way I know to actually delete references is from within the model's sketches.
You can Lock, Unlock or Break the references via right-clicking the part in the FM and selecting the List External References option.
Note: The option is only available if Ext Refs exists.
Thanks CBL.
I have looked at the FM and tried to delete them, but it does not allow me. Maybe I need to upgrade to SP4.1?
I have been having a lot of issues since loading 3.0. It could be because I have been away from SW a while, a little rusty... sleeping
Chris
ctopher's home
SolidWorks Legion
When you are in the open dialog box there should be a references button.  Click that and I think you can break all external references there.
DEddie,
I looked there and it does not allow the option for me to delete.
Chris
ctopher's home
SolidWorks Legion
Ctopher, did you find the solution to this?  I ask as I'm about to have to do the same sort of thing...
Chris, I agree with Matt on this.
Colin Fitzpatrick (aka Macduff)
Mechanical Designer
Solidworks 2009 SP 3.0
Dell 490 XP Pro SP 2
Xeon CPU 3.00 GHz 3.00 GB of RAM
nVida Quadro FX 3450 512 MB
3D Connexion-SpaceExplorer
Thanks.
Yes, I have found Matt's suggestion to work.
Wish it were easier...
Chris
ctopher's home
SolidWorks Legion
