FRP, Fiberglass Design Manual
I will be designing a fiberglass stair, does anyone know where I can get design criteria, properties, allowable stresses, etc. for fiberglass, thanks
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: FRP, Fiberglass Design Manual
I do a lot of FRP work, and I can tell you now that there are no two similar products.
Also we need more info the type of stairs you have and the FRP sections you plan to use ie SHS, Channel, ????, all these change the type of FRP material you have.........
When in doubt, just take the next small step.
Things to keep in mind are, generally FRP has a greater tension and compression ultimate strength, "E" is lower and shear strength is lower compared to steel.
http://w
