Tearout Failure
Tearout Failure
Tearout Failure
If the e/D is 2 or greater, do you have to worry about tearout failure or not? One of my team mates says that, if e/D is 2 or greater then, fatigue is not an issue, but tear out failure should be calculated. Can anyone help. Thanks
RE: Tearout Failure
In what sheet material? what thickness? single shear or double shear?
Don't think you can make a blanket statement about fatigue; depends on joint config, material, fastener, loading spectrum, etc, etc.
Why not just calculate the tear out as well as bearing static margins?
RE: Tearout Failure
Gotta' agree with SWComposites.  To make a blanket statement like this doesn't make sense.  Each situation is different.  If you are using 0.032" sheet to try and repair a skin on a commercial aircraft...probably not going to work.  Using it on an ultralight?  Different story.
2D is a good "rule of thumb", but you still need to do your "due diligence".
Garland E. Borowski, PE
Engineering Manager
Star Aviation
RE: Tearout Failure
and what's the connection between shear-out and fatigue ?
i would always check shear-out as one of the possible modes of failure.
fatigue is an altogether different thing, sure with a reasonable edge distance the Kt is pretty much 3 (for an open hole) but not something i'd dismiss.  possibly not something i'd spend a ton of time on either ... it depends on the structure involved.
RE: Tearout Failure
Hart-Smith recommended a 3d edge distance to prevent shear-out and a pitch of 5d to force bearing failure in preference to tension-through-hole failure.
