Faster way to drag "area" line?
This might be hard to explain, but here goes: In Mathcad 14, Insert > Area gives you two lines that you can use to collapse areas of your Mathcad sheet. You can drag the two lines up and down to surround your equations as needed. However, you can't cut, copy or paste these lines. If you want to drag the bottom line down to the bottom of a long Mathcad file, you have to drag it to the bottom of the screen and the window will SLOWLY scroll down. My problem is that I have several very long calculation files that I want to do this to, and the scrolling is so ridiculously slow that it seems like there must be a better way to do this. I can't cut, copy or paste these, either within the file or between different files. If I do this with the dragging method, for all the files I need to do it to, it's probably going to take me HOURS. This really sucks. Any ideas?
RE: Faster way to drag "area" line?
This way you can move ~5 pages at a time without scrolling.
Peter
