Can I open ".idi" files with I-DEAS?
I know it's the interoperability data interface, which allows you to export IDI files that can be viewed with viewers, but can they be brought back into I-DEAS?
I'm just a novice I-DEAS user, and someone sent me some .idi files that I'd like to open. If not I-DEAS, are there any free viewers available for download?
TIA
TIA
WinXP-SP3 / NX5.0.4.1 MP6 / Catia V5r18 / NX I-deas 5.3.0.14
RE: Can I open ".idi" files with I-DEAS?
As a workaround you could always convert the idi to a jt file using the iditojt.exe located in the gif directory. (you will need to run this in an I-deas command prompt).
Then import the JT into I-Deas by adding to an assembly and unprune to get the surface data.
