High pressure High temperature safety valves
Dear Friends and experts,
We are building a pilot plant, we have an issue with our boiler which needs a high pressure and high temp valve safety relief valve, which is holding all our plans.
so guys, I need your help if you have any info of such valves.
the valve specs
3400 PSI, 700 F, 1.5", when the relief opens the flow rate should match the boiler flow rate ( 3400lbs/hr)
This would be a great help friends.
Siva C
RE: High pressure High temperature safety valves
if you have the specifications, contact vendors and get quotes.
Consolidated Safety Valves is the leading supplier of US made boiler safety valves in the country. Followed by Crosby and Farris.
