center of gravity
center of gravity
center of gravity
I am using workbench 11.I want to apply force on the center of gravity for my unit. How do I do that? I dont know how to apply a load on center of gravity in ansys workbench 11. How to look for center of gravity?
thanks
Aditi
RE: center of gravity
How would you apply force to the center of gravity of the unit in real life?  I don't think that is possible...
Your best option may be to add an Acceleration to the unit.
Search the help file for 'point mass'.  You can assign a mass to geometry and use accelerations to load the structure.  Or you could ensure there is some sort of structure at the location of the CG so a point mass and a force could be assigned.
____________
JohnyGluebag
