a question about make up air unit
I have a project, there are 2 hoods exhaust around 3000 cfm air and I have to bring heated fresh air. but the gas landloard supplied is just enough for other service usage. I tried electrical heater. but that heater must to have around 75 KW power. that is a very big unit. What should I do in this situation?
RE: a question about make up air unit
what will the landlord supply handle at 14 inches?
maybe talk to someone up on gas regualtores and see if you could run a 2 psi system.
The way we build has a far greater impact on our comfort, energy consumption and IAQ, than any HVAC system we install
