Continuous Beam theory
Just a quick question... I'm trying to calculate the moments n reaction for a shaft with 7 bearings... I understand the 3 moments theorem but i m not too sure on how to implement it with 7 moments.
please can anyone provide me an answered example of a beam with any number of moments from 5 to 7 so i can try to figure out how i can solve my model?
RE: Continuous Beam theory
Calculate the simple beam shears, then use Moment Distribution to find the + and - moments, plus the additional shears at the supports due to fixity over the supports.
Easier said than done.
Mike McCann
MMC Engineering
quick question, long answer ...
you have a highly redundant beam (5 redundancies).  Moment distribution, as suggested by mike, is one way to solve this.  3 moment equation can be applied, i think it is an iterative process applied two two bays at a time; but this doesn't look near as elegant as MDM.  FEA would be a simple approach too, the model would be small enough to fit within most demo versions.
Yea, FEA would be the simplest. You will get a headache trying to find 5 more equations to utilize.
If you simplify to 1-D this can be done by writing your own code. I would write this preferably in Matlab.
I never heard of the "Moment Distribution" method. Maybe someone has a reference?
peace
Fe
Bruhn (Analysis of flight vehicle structures)
i think it is a reasonably typical "old school" structural analysis method (ie "back in the day" when FEA was difficult ...)
Oh ic.
Thanks rb1957.
peace
Fe
