What is meant by the term "misalignment" in a buttweld joint?
So this is question #3 in my series of "Pipeline Fundamentals"...
In Sec. 406.2.2 of B31.4, it says "Deflections caused by misalignment up to 3 deg. are not considered miter bends." What do they mean by "misalignment"?
Thanks!!!
Thanks!!!
Thanks!
Pete
RE: What is meant by the term "misalignment" in a buttweld joint?
prex
motori@xcalcsREMOVE.com
http://www.xcalcs.com
Online tools for structural design
Why would a degree specification be given if misalignment applied to the diameters?
Thanks!
Pete
You are correct in your assumption. "Hi-Lo" is the non-standard term while "internal misalignment" is the preferred standard term. The CWI exam contains a few questions regarding the use of standard and non-standard terms. Some others are "Fish-eye", "suck-back" and the like. Basically... just good old-fashioned welding slang.
Richard Schram
Mechanical Integrity Specialist
Pharmacia Global Supply Arecibo-P. Rico
rschram@pharmacia.com
as the comparison is to Miter bends, it seems that the code clearly means an axial misalignment which would simulate a small accidental Miter created during construction.
Was it a test ?
I hope I'm correct other-wise I'll go stand in the corner for an hour.
