Frequency range for measuring shock load on frame.
I am measuring the peak accelerations on a small tractor frame when running through a bumpy field. Someone has suggested that the frequency range be limited to 50 or 100 hz because the destructive forces are more prevalent in the lower frequencies. When I measure over a wider frequency range (0-1600 hz), the peak acceleration is 200 m/s². When I measure with a frequency range limited to 50 hz the peak acceleration is around 20 m/s². Which frequency range should I use to accurately discribe the load on the frame.
Thanks for your replies.
vechman
vechman
RE: Frequency range for measuring shock load on frame.
TTFN
I doubt you'll get much fatigue related to wheel inputs above 100 hz.
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
Have analyzed failures where the low amplitude/high frequency range had more effect on the failure (wind vibration on transmission structure)
