Cracked Hardrubber lining in a magflow tube
Hi ,
I have a magflow tube with a hard rubber lining. Unfortunately the flange of the pipe hit the lining and cracked it. Is there any paste or glue type material i can use to fix this crack so that water does not seep into the flow tube.?
RE: Cracked Hardrubber lining in a magflow tube
regards
corrosionman.
