ASME B31.3 Code Compliant Flange Bolting
Hello All,
I have been charged with ensuring B31.3 code compliance for a packaged process plant being built at my company. All the piping comes under the same criteria, but I have chosen the highest pressure and temperature line for an example.
6" sch 40 pipe ,A105 600# flanges
Fluid: Gentron 245fa
Design temperature: 500 F
Design Pressure: 880 psi
In specifying gaskets we chose Flexitallic style CG gaskets. Bolting will be as follows
A193-B7
B31.3 Ultimate per table A-2 = 125 ksi
B31.3 Yield per table A-2 = 105 ksi
B31.3 Allowable stress per table A-2 = 25 ksi (within my temp range)
The problem comes about from the Flexitallic installation procedure which calls out a target stress of 40 to 50 ksi. A little bit of research showed these values came from ASME PCC-1 (table 1) which is referenced for use in flange bolting by ASME B16.5 (Par 2.2) which in turn is called out by B31.3 for use in specifying compliant flanges.
A quick check using the BPVC Section VII div. 1 app. 2 rules for flange design showed that for the gasket in question a bolt stress of 11.8 ksi should be adequate to maintain joint integrity for both operating and gasket seating loads.
I am planning to specify bolt torques leading to about a 20 ksi per bolt stress for these joints. My question is as follows.
What is normally done in industry when specifying code bolting? Use of the vendor information would lead to a code violation on bolt allowable tensile stress. Ignoring the vendor recommendations and using my own calculation would lead to code compliance but I am concerned with the joint integrity since I didn't follow vendor recommended practice on installation. Any advice from experienced hands would be greatly appreciated.
A193-B7
RE: ASME B31.3 Code Compliant Flange Bolting
ASME Section VIII, Division 1, Appendix 2 is for the DESIGN of the non-standard flanges. Refer to Appendix S that indicates that much higher actual assembly bolt stresses may be required.
This is where the Taylor-Forge method becomes funny, and where you realize that some of the factors in the moment load equations are actually fudge factors.
