API 5L OR ASTM A53 GB SEAMLESS
They have the same mechanical properties which is the criterion to select
Conditions
Pipe oleoducte oil: service: diesel, gas90, naphta
Pressure 1000 psi
Temperature : 50 celsius
Length : 7 km
Pipe oleoducte oil: r7. heavy oil
Pressure 1000 psi
Length : 7 km
Best regards for all your comments
Conditions
Pressure 1000 psi
Length : 7 km
Pressure 1000 psi
Length : 7 km
RE: API 5L OR ASTM A53 GB SEAMLESS
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
But that material will be mandatorius??, why? here I attach a plane, am analyzing a crossing of buried pipeline and have to decide, please recommend to me some reference where to consult for material , i have to chose between API 5L oe ASTM A53 GB
Tanks for ur comments,
Cesar
A footnote...B31.3 also allows API 5L per one of the last footnotes to Table A.1.
SNORGY.
Most seamless carbobn steel pipe is quadruple stamped as A-53 B, A-106, API 5L B & 5LX-42. Take your pick.
Not sure what planet I was on that gave me the idea that the B31.3 material substitution was relevant here.
I think I'm losing it...been on vacation for too long.
SNORGY.
