modeling infiltration chambers
I am designing an underground infiltration system and want to utilize sidewall discharge under wetted perimeter and exfiltration under outlets. When I click off wetted perimeter, there is no option to enter it and I am getting an error. Is the wetted perimeter option under a separate dialog box?
RE: modeling infiltration chambers
If you use the velocity option, you can apply the velocity over the "surface area" or "wetted area". Using "wetted area" will allow flow through the sidewalls.
For details please see www.hydrocad.net/exfilt.htm
What is the error message? Most mesages will also have a help button for additional details.
Peter Smart
HydroCAD Software
www.hydrocad.net
thanks for any assistance
If there is also an error message, what is the message?
Peter Smart
HydroCAD Software
www.hydrocad.net
