Array fillets
Array fillets
Array fillets
Hi
Why cant we array the fillet on the extrudes.
See attached img. After the rectangular array, I need to use this rect array in a circular array.
Thx
C1
RE: Array fillets
Can you post the part for testing?
Are you getting any error messages when applying the pattern?
Which pattern function and options have you tried?
RE: Array fillets
Are you trying to make the pattern of the fillets only?
It is better to pattern the entire extrude feature with the fillets instead.
Artem Taturevich, CSWP
Software and Design Engineer
AMCBridge LLC
www.amcbridge.com
RE: Array fillets
For mysake, I wished I could send the part but I cant.
I could figure out more details. Actually I can pattern the extrude and the fillet. But there is also a draft of 3 deg on that extrude. This is the issue, it wouldnt array.
Dont know why. I have unchecked/Checked the geometry pattern also.
Thx
C1
RE: Array fillets
I can't recall ever being able to array a fillet feature.  I think it has something to do with the end conditions and the surface ID's.  I could be wrong or maybe i'm just on an older version (sw2008 still)
